Matco wheel bearings slinging grease
goatflieg
Friend
During postflight inspection yesterday I noticed this. Not sure when it may have started; not noticed until this walkaround. These wheels have only seen some normal taxiing, one high speed taxi and five landings. The photo is of the left wheel; the right also showed signs of grease oozing past the seals but hadn't gotten enough out to fling onto the rims. Is this normal for new wheels? Should I be rechecking my bearing tightness? Any input on this output would be greatly appreciated.
AM-JKLXaSXp4TLQeg-ll0VHm7iv7v1iZDs6kCYZqUcRKtAyE0Kbu2BPUdpbIEBmpxfkkv5L1SEFSxiNiBarglXC9L3-8EXm8EudCrLDOM4tl1b9e9AAnrPOEI8kTmwFVGDnRImXuJmWkqiIXlMBS0zGquxyk=w900-h600
This looks like the newer rubber seals and It looks like the inner lip of the seal is not riding on the spacer, but rather forced inward. I would pull the nut and spacer to make sure the seal is seating correctly.
Mine did this too after first flight. I determined after asking some peeps on the forum that there was just likely too much grease. Now I keep it a little bit on the lower side and haven't had an issue. Basically, I don't pack them full anymore.
After jacking up the wheels, pulling the nuts and inspecting, it looked to me like the seals are seated correctly, so I was thinking the same thing. Wiped off the grease and two more landings showed no more seepage. I'll keep monitoring, of course.
Exactly what I found too. Keep on keeping on!
P.S. congrats on first flight! I must have missed the post.
