Michael Burbidge
Under the section titled "Fitting the tank to the wing" there is a line that says, "Drill the three bolt holes on the inboard bracket on the main spar". I'm not sure what bracket this is referring to. I think it is the inboard attach angle. The one that has a blank flange. But the instructions have always called this an attach angle, not a "bracket".
Can someone confirm for me that this line refers to match drilling the inboard most attach angle using the middle hole of the plate-nut holes that are pre-drilled in the main spar.
