mandm1516
I've decided to install rear rudder pedals and am trying to figure out how to match drill the idler bracket to the gear support tower. As you can see from the picture (the left bracket is laying flat next to the 2 bolts--the notch on the right side of the bracket will be up when installed). The outboard (top in the picture) hole is already drilled. I can't figure out how to match drill the other hole (bottom bolt in the picture) because there's not enough room to get a drill & bit through the other bolt hole coming from fore to aft (right to left in the pic). Any tips?
[/URL][/IMG]
Thanks!
Thanks!
