I've been staring at this too long and not sure if I'm setting this up correctly.
I used 3/4 angle on the bottoms to line up all the pedals. I wanted my pedals a bit forward from vertical so I clamped a .125" straight bar across the front of the pedals and then clamped that to all 4 pieces. (c-clamps holding that). It's exaggerated in this picture, but it's probably only 5 degrees. That raises the attachment point for the bottom of the main cylinder too low without the proper edge distance.
If I decrease the forward angle so I'm back within tolerances on the left pedal, the right pedal would be forward of the rudder weldment. A) is that correct? B) how do I get all to align since the 2 pedals are different angles?
Does anyone have any pictures showing this?
Thanks!
[/url][/IMG]
![](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2Fn3wskBM%2FIMG-7621.jpg&hash=dda9208cd3e4cd868b88a0f2f2492939)
Thanks!
![IMG-7620.jpg](/proxy.php?image=http%3A%2F%2F%5Burl%3Dhttps%3A%2F%2Fibb.co%2F023w6YH%5D%5Bimg%5Dhttps%3A%2F%2Fi.ibb.co%2FW51TMBm%2FIMG-7620.jpg&hash=f18ac3cbd73950b98a34d159f80f9c52)
