master cylinder dimensions
rv9aviator
Can someone tell me what the hole center distance is on their RV-10 Matco brake cylinder? I am modeling the tubes, pedals and cylinders and need the distance between the holes.
Thanks!
The brake pedal guy
Using my machinist scale I came up with 2 and 13/16 inches. I measured to the center of the plastic dust plugs. If you need more precision I can pull out the calipers.
This was the hole distance for the lines themselves right?
Rick S.
40185
Fuselage
