LettersFromFlyoverCountry
Wondering if anyone has had a problem of manual trim messing up two nicely counterbalanced elevators and, if so, what the solution is.
The particulars of my problem along with pictures are posted on the blog but basically, the attaching of the manual trim cable seems to want to pull the after part of the elevator lower.
I messed around yesterday with changing the amount of cable in the HS to no avail. I figured maybe it was acting like a "stick" to push the aft end down.
I have the "old style" counterbalance weights and I've already put the tips on and fiberglassed over them so there's some limitations I have adding weight. Plus there's the question of whether I should add weight to elevators that are already balanced?
![2012-03-03_13-06-00_732.jpg](/proxy.php?image=http%3A%2F%2F2.bp.blogspot.com%2F-kROFovMCM2A%2FT1KKoJuFxrI%2FAAAAAAAAEJI%2FZTsjwYZhw3I%2Fs400%2F2012-03-03_13-06-00_732.jpg&hash=ea2e5e04138c5d3a2cf04ad65777dea8)
