The elevator has a treaded bracket riveted into the bottom skin. The cable housing end screws into the little bracket. The path for cable through the horizontal stabilizer and fuse bulkhead is too twisty/rubbing to simply screw the cable into the elevator bracket.
On my 3B , I extended the cable out far enough to tread the elevator on the cable, then push the cable back end to install the elevator. THIS REQUIRED ROTATING THE ELEVATOR LIKE HALF PROPELLER due to the treaded arrangement.
I am ready to install the elevator on 4 my project. CAN YOU RECOMMEND A BETTER WAY TO GO ABOUT THIS TASK ?
