Hi all,
Working on my standard build RV8's manual trim cable routing.
Can anyone point me to the plan or OP DWG that depicts the proper location of the 5/8" hole that accommodates the passage of the manual trim cable through the aft side of the left hand gear tower (just in front and slightly below the throttle quadrant). If not a plan sheet number just a dimension to locate.
Thanks kindly for your help...
