I started the 9A project planning to go with manual trim. After fuselage construction I was not all that happy with the manual trim system. With the finishing kit I ordered electric trim kit. Well finally got around to fitting the servo. The trim tab horns I fabricated some years ago don’t work with the limited travel of the servo.
The question is, is there a way to modify the installed horns to work with the electric trim servo, without removing the horns and perhaps pop riveting (cheerymax) replacement horns
will be ordering the parts to build a new trim tab in the am. Good advice!
