I have been checking out the manual pitch trim cable and the routing from the fuel valve cover plate through the main spar. That first bend where the cable turns almost 180 degrees and heads to the aft looks really tight on drawing 32A.
When I laid the cable out on the work bench and tried to put a bend in it I could get to about a 3 inch radius without major strain on the cable but the drawing looks much tighter than that (maybe 1.5 inch radius). I'm afraid the cable will take a set and the smooth action of the vernier control will be compromised. My gut says to check this out before just forcing the cable into this tight of a radius.
Can someone who has installed the cable tell me if the bend radius shown on drawing 32A is an accurate depiction and if the vernier works smoothly with that tight of a radius? Any photos of the cable routing in this turnaround area would be great. This may be one of those cases where you can just trust the Vans drawings and go with it and it works fine but it looks risky to me.
I am installing manual pitch trim with fuel injection. I just recently came upon the note buried in the instructions to order the longer trim cable if you have a fuel injection boost pump. I still have the standard pitch trim cable that came with the fuselage kit and I have hesitated to exchange it because I am using an Andair boost pump. It is very compact compared to the Airflow Performance boost pump and it looks like I may be able to route the cable "normally" with the Andair pump and plumbing. If anyone has done this, or tried and failed, I would love to hear about it and see photos if possible.
Thanks in advance to those who can contribute to this discussion.
John Harrell
RV-7A
Emp done, wings done, building fuselage
http://www.johnsrv7a.wordpress.com
John Harrell
RV-7A
