I've been humbled setting up the aileron manual trim.
How much force is the friction block supposed to provide? I set it up to have a fair amount of friction, and the adel clamp at the handle side will not hold the cable casing without it slipping off. So it seems I'm setup for more force than a Bowden cable can transfer. But if it isn't enough friction it will just recenter and not keep position in flight. So how much is right?
Is there anything I can do to have the Adel clamp grab the cable casing better so it doesn't slide around?
Has anyone had to open the hole in the center of the friction block so that the action of the bolts on it is more meaningful? My adjustment range with the bolts is from pretty tight to unmoveable.
