Manual Aileron Trim Adjustment Range
TX7A
For those of you that may be flying, or may know the answer to this:
What is the range of average/normal adjustment of the manual aileron trim?
In other words, let's assume the plane is trimmed-out and the trim pointer is pointing directly aft...centered-up. What would be the most degrees of rotation, right or left of center, that one might expect in trimming out roll.
I'm working on a mod that includes the elevator trim & I need this info.
Thanks for any knowledge on this.
Sam
7A, cabin stuff
Without going out and measuring, I'd guess it's pretty close to 45deg either side of center. The seat cushions can interfer with that much travel depending on the type of seat, so a different handle might be in order. I found a screen door window handle at the hardware store that works well.
