N788RV
Active Member
I have a Dynon D120 EMS and not sure how to mount the manifold pressure sensor. It didn't come with much guidance. Should it be mounted on the firewall or should the line pass through the firewall and mounted inside. Dynon says it doesn't matter but I saw some other posts that talked about crud and moisture causing problems. It would be great to see a picture of a few installations.
