Jerry Fischer
Problem MP started acting erratic. 0-5psi then drops to zero.
Checked fittings from #3 cyl head up to MP sender on FW. Replaced loose 45 deg elbow(.040) at cyl head with brass male/female (1/8NPT, .040)and added the 45 back on end to accommodate 1/4" line back to sender. Used red Loktite on Pipe threads being careful to keep out of fitting orifices.
Also stuck my head under the panel and checked the little 1/8 flex tube for brittleness/cracks etc. No joy, so I suspect the MP sender. Just looking for someone who has experienced these symptoms who could confirm (before I spend another $58 at ACS) os send me in the right direction.Thanks for any help.
