I looked and couldn't find my write up - so more detail
[You have not idea how frustrating it is trying to provide detailed error free instructions and have this link time out tell you you have no authorization to make a change and throw all of your work away - I did it again. I hope this information is understandable at this reduced level of detail.]
Original riveted installation:
Rivets drilled out:
Original hole cut with a round hole saw (in a drill). This is elongated to remove and reinstall the torsion bolt (AN3 I think).
Step removed. The plates are clecoed to the inside of the skin through #30 holes that will be the location of the plate mounting - not the step mounting. If you look closely you will see the extra 4 holes that are the location of the plate mounting separate from the step mounting pattern. The step mounting holes in the skin are used as a drill guide for the #30 step mounting holes in the plates. Clecoe each hole after it is drilled to assure perfect plate alignment:
Platenuts mounted on nutplates. After all the holes are drilled the clecoes and plates are removed and a nonfloating platenut of the required double ear or single ear type is clecoed (bronze) to a screw hole and the platenut is oriented to the desired position. A #40 hole is drilled throught the plate using a platenut mounting hole as a drill guide. That holes is also clecoed (silver) and the other platenut mounting hole is drilled with a #40 drill. Everything is removed and repeated on the next screw hole until the mounting holes for all of the plate nuts are drilled. Go back and enlarge the #30 Screw holes (NOT THE #40 RIVET HOLES) to 3/16". Debur the holes dimple the screw holes in the nutplate and the fuselage side skin and rivet the DIMPLED (manufactured with a dimple at the screw hole) platenuts to the nutplates:
Racing coverplate bare and painted
http://i446.photobucket.com/albums/qq186/raxsom/IMG_0004_zpsfa07032e.jpg[/IMG
I switch back and forth between steps and racing cover plates (0.4 kt gain in speed) but the covers are on now and I don't have a photo of the steps mounted with screws - I hope it is obvious how this works.
Bob Axsom
