A little tip: When you need to make the various "spacers" (e.g., F-1287H, etc.), cut the 5/16" tubing to approximate length, chuck the tubing into your 3/8" drill press, turn on the drill press, and carefully lower the tubing end down onto a flat file positioned on the drill press table. The tubing end will be nicely squared-up and finished. Occasionally remove the tubing from the chuck to check that the overall finished length is what you want. Just be careful that the file's slight movement doesn't get away from you. Onward and upward!
