..Quite a few folks have put inspection panels there but their usefullness is somewhat limited because of the middle structure blocking access to the rear of the instrument panel.
Mike,
What thicknesses of material did you use?
For those that have installed these inspection panels, how have you dealt with the fact that Vans recommends against putting large holes in this highly stressed region, where engine and prop loads are transitioning from the firewall to the airframe? Did you go manufacture your own skin from thicker stock and / or reinforce the panel cutouts?
