eric_marsh
I've got my spar in the jig with the main ribs clamped to it and am ready to start drilling the ribs to the angles and then the spar. Looking at SK-33 (I can't seem to find SK-3) and reading the instructions I see that I should be aligning the ribs vertically before I start drilling. I'm finding that there isn't enough vertical play to get all the rear indexing holes to within less than a quarter of an inch of each other. The flanges are square where they attach to the main spar. My kit was made in 1995 or prior to that. I'm wondering if manufacturing variation would account for what I'm seeing.
After coming to the conclusion that I'm not going to get the indexing holes lined up by moving the rib up/down in relation to the spar and wondering how to deal with the situation I laid the rear spar onto the ribs and clipped the spar and ribs together. That seemed to more or less pull the trailing edge of the ribs into place. Looking things over it occurred to me that I might do well to drill and cleco the ribs to the rear spar and then do the same to the front. It will put some tension on the ribs but I don't see another way around it.
Actually, trying to move the front of the rib so that the rear lines up doesn't seem like such a hot idea anyway. Some of them are shoved all the way in one direction, others in the opposite direction (as per the last photo which I'll admit is a little hard to make out). That, in turn, is bound to have an effect on how smooth the skin is from rib to rib.
Is there anything that I'm overlooking here? Does that seem like a reasonable approach?
I don't want to go messing anything up so I'm going to spend a little time pondering this to see if I can come up with any other ideas.
