CharlieWaffles
I have noticed a squeaking noise coming from my right main gear if there is a side force applied to the plane (push the plane from the side). It also occurs when turning the plane while taxing in some directions.. If I manually push the brake pad temporarily away from the rotor the squeaking stops. The noise only happens with a side force, a forward or aft push does not produce the noise.
I suspect there may be a small amount of side play with my wheel. I am thinking I need to lift the right wing to take pressure off the wheel, and then remove the wheel, check that the Brake Mount and Brake Torque Plate are secure and then tighten the axle nut tighter than before if the mounts are ok. I am using an after market spacer for the torque plate spacers so its not a geometry issue there.
Has anyone else had this issue before? Other suggestions?
