Zuldarin
Greetings, I am getting ready to ream the main gear mounting bolt holes to .311. I have read numerous posts about using a taper pin on the nose gear, which I plan to do, but I haven't read anything about the main gear. Is it recommended for the main gear or should I use the standard Bolt as outlined in the plans?
Thanks for the advice!
Darin
Darin
