I am mounting the WD-921-L-PC gear mount for the mains for an A model. The fuselage was built as a tail wheel, so I am having to put them in out of normal build order. It is going fine until I tried to fit the gear tube in the hole in the floor. The pattern clearly shows removing some of the gold flange on the spar. There is NO WAY I am removing anything gold without seeing if that is correct. I don't think there is much if any strength from that flange right next to the edge, but wanted to see if it is standard procedure. You can see the area in the photo marked in red. I will get the aluminum shavings out before I do a final fit. Thanks.
[/IMG]
![gearmount.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi1245.photobucket.com%2Falbums%2Fgg582%2Frockwoodrv9a%2Fgearmount.jpg&hash=d8d5d4b156d67d6e01b004c00deeea57)
