LR60
Active Member
I am adding an 8 circuit Fuse block to cover miscellaneous circuits that I don't want on my main CB panel. (saving some CB spots for future upgrades)
What is best practice to feed power to this Fuse Block?
Should this feed wire be protected?
Should feed wire size for the Fuse Block be based on actual loads or should it be based on future higher current loads if Circuits are added.
Thanks in advance
Mark
Thanks in advance
Mark
