HOWDY ALL,
I'm considering mounting my Garmin GMU22 in the tail section on the platform between the horizontal stabilizer. There are 2 steel cables for the trim and mounting hardware for the horizontal and the vertical stabilizer that are steel. Do we see this as a potential problem? The mounting location is closer to the cables than what they recommend, which is 3 feet. The cables are about 6" on either side of the magnetometer.
Have others used this area without problems?
By the way "Stein" and his boys did a beautiful job on our panel. I will send photos when it is installed!! I'm getting closer to the end, although it has been 10 years..YIKES
Thank you again for you valued input!!
