Bubblehead
I'm having occasional rough running engine problems. I've troubleshot the fuel and air systems and they're fine so my attention is now turning to the Bendix dual mag and wiring. Can someone recommend a mag shop in the area that can do a bench test of my mags and ignition leads?
The engine seems to run great until I do a long descent to an airport. Once back to about 2500 MSL it starts running rough despite being full rich, switching fuel tanks, and turning on boost pump. Fuel pressure steady at about 28 without the pump and 33 with the pump. Next time up I'll try a mag test while it is running rough.
Compressions are all at least 75/80 and the timing checked right on.
