I have a standard ignition switch and a slick 6393 mag on the left, which I presume has a retard breaker. There is a LR (retard) post on the back of the ignition switch. Question is where does this connect on the mag itself and what type of wire? Is shielded wire same as P leads used? Related question is whether the shielding for the P leads connects to the ground post on the switch or whether it is only connected at the mag.
