vbpiper
Forgive me if this has been covered in the past, but several searches of the archives did not produce an answer.
I am in the process of wiring my Slick magnetos with 18 gauge shielded wire and I am using the ACS key switch. It appears that the center conductor is to be connected to the P-lead on the mag and the appropriate terminal on the switch ( "L" or "R"). I have the jumper installed on the switch as instructed for the impulse-coupled left mag. Then do I connect the shield to the ground terminal on the magneto and leave the shield unattached at the switch end? No attachment to the engine ground or the engine-side of the ground block on the firewall?
I am so confused!
Thanks in advance.
PS Have a Merry Christmas!!!!!
Thanks, Doug, for another great year of VAF.
I am so confused!
Thanks in advance.
