kjelle69
Active Member
I am thinking of changing my Aluminium fittings to steel.
I have a straight fitting and thats no issue but I also need a AN804-6 fitting.
Looking at the recommended pump fittings when you have an elbow fitting attached to the pump it seems that it's a washer combined with an O-ring that is needed. That makes sense but is the washer of some special type? In the attached image it also seems that there's actually two washers or an O-ring combined with a second washer. I dotn really get this?
