Ben Beaird
Active Member
I recieved this Mandatory Service Bulletin from Lycoming;
http://www.lycoming.textron.com/sup...enancePublications/serviceBulletins/SB565.pdf
They sent it to me because I have a 2001 C172 with an IO-360 in it. However, the high pressure mechanical fuel pump used on the IO-360 is also the same pump used to replace the stock low-pressure pump on the O-360-A1A when it is converted to fuel injection.
Since I installed an AirFlow Performance fuel Injection system on my RV-6A's O-360-A1A, I had to purchase an LW-15473 (covered by the S.B.) high pressure pump from ACS.
I'm posting this in case there are others that have the same set up as me but are unaware of the S.B. It seems to be a serious one.
Ben Beaird
Plymouth, WI
-6A
Ben Beaird
Plymouth, WI
-6A
