mahlon_r said:By putting a forward facing sump on, as Oxsuser suggests, you would be basically converting the engine to an IO-360-A1B. The A1B is the non-counterweighted version of the 200HP IO-360-A1B6 that Vans sells.
Good Luck,
Mahlon
“The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at you own risk.”
RV8N said:My engine started out as an IO-306A1A from a 1966 Mooney. A previous owner swapped out the -A sump for a -C model to install it on a Velocity. At the time, -A model sumps were unobtainium... very rare and desirable (and expensive). I have a friend that modified the -C sump back to a forward facing throttle body for his Skybolt and he recommended that I do the same.
Karl
