Autofuel in the -10
For my RV-10, I intentionally sought an O-540 (B1A5 now B4B5) that was rated for 80/87 octane, low compression, 235 HP engine so that I had the autogas option. There are few on-field stations for it but we have purchased a used 50 gallon tank and can get 89/93 non-ethanol octane fuels at a few places by truck. Often marinas or rural fuel stations like Southern States will have non-ethanol fuel.
For a fill-up, you are talking a savings of $120 per tank, or 40% ($2/gal X 60). I sense no difference in the fuel behavior or engine temperatures and have no sparkplug fouling with the autogas, of course, since there's no lead to accumulate.
The downsides of the carbureted engine are the inability to control the fuel flow as precisely thus the efficiency is lower, and the cruise speed is lower with a 2575 RPM max, or proportionally, the effective thrust at same % reduced power. It would be possible to put FI on the engine even with the lower compression setup to improve fuel efficiency.
