Mr Charles
I have a RV-4 built in 93, that I purchased 5 yrs ago...I was going to switch from a FP to CS prop, but after some investigation I think I might have a solid crankshaft
. No data plate on engine...aircraft engine logbook has "A1A/A4J" penned in under "model", while dataplate on airplane has A3A stamped in model...
Lycoming 180 hp, has bendix fuel injection, inverted oil, and slick magnetos...however, right side had an electronic ignition self contained distributor that failed and no parts were available to fix, so bought a regular mag to replace...I have located some casting numbers and stamped number on case, and on accessory case...How can I determine if I have a hollow crank or solid, and how can I determine exactly what variant engine I have?
Thanks for the help!
Charles
Charles
