I had to remove the accessory case on my O-360 to replace a leaking oil seal. I have reinstalled the case and I notice that the gasket is approx 1/2 inch too long. Should it be folded and put under the sump gasket or simply cut off and some RTV applied to the corners of the the sump/assy case intersection? Just trying to avoid any leaks.
John in Fl
John in Fl
