PandaCub
Greetings, all - I did a quick forum search and couldn't really find anything:
1) What are folks using to clean and lubricate the piano wires holding on the cowl? Mine are getting pretty tough to pull out and push back in. I'm thinking a good degreaser and then some kind of lubricant: silicone, lithium grease, or (gasp) WD40?
2). Sometimes my starter just clicks once and doesn't turn over the prop. I may have traced it to the starter gear (aka "Bendix gear") not always engaging with the prop gear. Any recommendations for a lubricant that might help those gear teeth play nicer together?
Many thanks!
-PandaCub
Many thanks!
-PandaCub
