I did some blind riveting yesterday, and started to have problems that seemed to escalate. Riveting my bulkhead caps on with LP4-3 blind rivets using the swivel head pop rivet tool supplied by Cleaveland Tool in 2015 (they sell an almost identical puller with a different brand name now; don't know if that's an issue). We've all had blind rivet mandrels pop in the wrong place, leaving a long tail. Well, yesterday it started happening a LOT... by the time I was done, I'd say one out of four mandrels broke in the wrong place.
When this happens, the internal jaws can no longer get any purchase on the mandrel, and I had to remove the interchangeable nose piece to get the jaws to engage. I had to make a steel spacer with a mandrel-sized hole drilled in it to act as a nose buck, and getting the long mandrel tails to break inside the rivet took a TREMENDOUS amount of force. Not sure what's going on here; I disassembled and inspected the tool; nothing seemed amiss. It was a mixed batch of LP4-3 rivets supplied at different times; could I have some bad rivets? I don't know much about the physical properties of the LP4-3 rivets, and I'm confused about why some rivets popped correctly and fairly easily, and the huge increase of effort it took to pop the ones that didn't pop correctly. What am I missing here? I will be making inquiries to Cleaveland Tool and Van's... but wanted to get VAF input as well.
