Doug
I have just carefully fitted the lower fairing to the rudder and was pleased with the fit until I mounted it on the VS. I have considerable interference with all three three VS/tail wheel weldment attach bolts.
I have tried turning the bolts so the bolt heads are aft - but I still encounter interference at about 30 degrees deflection.
Access to fit the nuts is almost impossible with this bolt orientation - so now I need to ask what do most folk do here?
Do I need to bite the bullet and hack clearance holes in the fairing or is there a better solution out there?
Doug
RV-6 Finishing - Ha, I am kidding myself!
Doug
