mkbreezy
Member
I am replacing the lower rudder cap on my 9-A because the back end cracked open at the bottom and the nav light was falling out.
On the new part, there are two faint molded in cut lines. I am assuming that the lower line is for the RV-9 because it lines up (sort of ) with the old part. Is that assumption correct?
Also need some ideas to mount the nav light screws so that the cover can be removed to replace the bulb without removing the rudder cap. (Not putting LED's in)
