heres how I do it
the cowl dance ---
Position prop horizontal
Right hand holding left inlet, Left hand under cowl near center
Face the prop with the cowl hanging down in front of you
Squat down as you slide the cowl under the engine
sight under the prop and you can see both upper aft corners of the cowl as you begin to raise it into place and guide the aft corners to the outside of both gear legs
continue to raise the cowl with the front higher than the back
as the front slips under the prop spinner, raise the back
engage the back vertical hinge on the right side (your left) with the fire wall hinge. does not have to be perfect, just engaged. With this supporting the right side of cowl, your left hand can continue to support the cowl from underneath as you walk around to the left side of the aircraft (to your right) and fully engage and pin that side
keep supporting the bottom with your left hand and walk to the other side, Trading the right hand under the cowl for the left hand. engage the right side hinge and pin it.
voila done
can do it with a bit of practice with no scratching and in about 30 seconds.
If you have a 3 blade prop ..... punt!
