Barneybc12d
![eve0iu.jpg](/proxy.php?image=http%3A%2F%2Fi60.tinypic.com%2Feve0iu.jpg&hash=fb874d031ce673374faa0f4ce8e35a70)
Looking aft at the last bulkhead (F-01412) in the tail.
I haven't run across this before, but I will trim this tab so it sits flat.
![2e3cyv6.jpg](/proxy.php?image=http%3A%2F%2Fi58.tinypic.com%2F2e3cyv6.jpg&hash=e7fdbd977314589281df40fe1f94571a)
This is where the side skin overlaps the aft bottom skin. I did put a slight break in the side skin, but the gap is about .040. Is this normal or should I try to get a tighter joint? The joint between the side skin and the bottom skin is tight.
