Run up was fine. At rotation oil pressure gauge went to 7psi at 5150rpm at climb out. While in the pattern to return to the runway the gauge bounced between 12 and 25. Burped and checked oil level and it was fine. Any ideas of where to start looking, oil pressure valve, oil sender, loose wire ??? Thanks for any input.
