I've been wrapping up the deficiency list for the past month since the FSDO folks gave me a few items to comply with. Anyway, I started the engine for the 2nd time this morn. It's a factory new Lycoming 0-360 A1A, with the cowling off, so I limited engine run to about 3 minutes between 1200-1800 rpm. Similar to the first brief engine run, the oil pressure remained in the yellow arc at 45 psi. During the same engine run, the fuel pressure stabilized at 10, well above the red line @8 psi. I'm using standard analog Vans gauges with the Van's supplied transducers. My hunch is that the gauges are giving me bad readings. As expected, the Lycoming supplied data sheet shows the numbers in the green during their test run.
Any chance that there's some air hanging around at the transducer that could cause bad numbers and/or two bad transducers and/or gauges??
Jim Diehl
N901DD
RV-7A
Jim Diehl
N901DD
RV-7A
