David Shelton
I believe it might be helpful to compare our door problems/solutions with those of the DA-40, which has a top-hinged passenger door. An estimated 31 rear passenger doors have departed Diamond DA-40 airplanes while in flight. This is 7.2% of the 428 airplanes in service.
The main cause was found to be "the crew not properly securing the rear passenger door prior to flight." The proposed AD would require installation of "an improved retainer bracket to prevent the passenger rear door fully opening in flight." The FAA has issued a notice of proposed rulemaking which would include installation of a new retaining bracket.
FAA Docket: http://edocket.access.gpo.gov/2010/2010-21068.htm
Diamond Service Bulletin: http://www.diamond-air.at/fileadmin..._Bulletins/SB40-070-0-M-pax-door-complete.pdf
At first glance, the basic retaining latch appears similar in design and function to the Vans latch. Does anyone have any good pictures of a DA-40 retaining latch?
