db1yg
After the paint work was completed on my RV9a I have determined that I lost 3 kts tas at curise power settings. This was confirmed on numerous flights using identical power settings and density altitudes as those captured during many pre-paint flights.
I initially concluded that I must have installed some of the wheel/leg fairings out of trim upon reassembly after paint, but that was checked by a full realignment process with the aircarft on jacks--just like I did when making the initial install. Still missing 3 kts.
I then re-checked the pitot static for accuracy in flight by doing box runs (N., S., E., W.,) in smooth air with a/p engaged, capturing the gps ground speed data, and converting to actual tas using Kevins spread sheets---still no joy.
I have a theory on what happened but I would appreciate any ideas that others may have on the lost ktas.
Best Wishes and Cheers,
db
RV9a/ECI0360/James Cowl/Catto Prop--102 hrs and a permanent smile!!!
db
