Fearless
I am slowing acquiring components to put my engine back together. I was going through the engine log for my O-320 D3G core and see where they replaced the engine mounts at the last overhaul. They were Lord mounts J9613-40 and J9613-53. Reading through past posts I see references where people have only used the J9613-40 mounts for their RV's. The engine was taken from a Piper airframe. So I'm wondering do I need to get the difference parts numbers or will using the J9613-40's on all four corners be correct for the Vans dynafocal 1 mount? If I do have to use both the 40's and 53's which ones are for the top and which ones for the bottom?
On another note I looked up the N-number for the airplane the engine was taken off of and the number is now assigned to an Airbus 320.
