Van's standard cowl - actual pressure recovery data
Years ago, I installed a pressure manometer in the cockpit, with lines running out to the area just above the crankcase, as well as one behind the engine, just in front of the firewall. The pressure recovery was almost perfect, meaning that if one put an altimeter on the line to the area above the engine, it would agree with the one from the pitot tube. This isn't how I did it, but the result was the same. I measured pressure differential, in inches of water, from the line above the engine to cabin static. I used Bernoulli's equation, together with the TAS, to get this data.
My conclusion from these tests is that there was nothing meaningful to do with the top portion of the cowl to improve cooling or significantly reduce drag.
There could indeed be some misbehavior in the SJ cowl - two 7A's in this area have them, and both have fought high temps. Non-complete pressure recovery is what will cause what Don is referring to, together with WOT.
Someone needs to instrument the SJ cowl the way I did the standard one. I'll talk to my hangar mate about doing this.
