andrewbutler
Member
Hello,
I have a zero timed IO360 with a Lycoming core and Superior Millennium cylinders. Engine is equipped with Silverhawk EX FI, One Slick Mag on the bottom sparks and one PMAG on the top sparks, both timed to 25 degrees BTDC (I haven't connected the MP to the PMAG yet).
I checked out LOP operation yesterday on a cross country at 8,000 feet using the LOP mode on my AFS3500. Everything happened as expected (from reading JDs Pelican's Perch articles), and the engine ran smooth as I leaned all the way to a noticeable power drop. I stopped when the power drop of the engine became excessive. See picture for the numbers I was getting at 25.5 litres ph (6.6gph). A couple of times though when I was tweaking with the mixture, and power dropped even further, the EGTs shot up. This was rectified by increasing the mixture. Is this normal behaviour? If so, what is happening in the cylinders/exhaust to cause it? If not, what may be the cause?
I checked it again today on the return leg, albeit as a lower altitude of 2,000ft. To compensate, I kept the power below 55%. The same thing happened when I went way lean, with EGTs dropping back down again immediately when I reduced the lean slightly. I didn't leave it like that long enough to observe any changes in the CHTs, which hovered around 320 or below throughout.
Running LOP is must have in a country where AVGAS costs ?9 per US Gallon, thats about $13 at today's exchange rate!
Any help would be much appreciated. I want to make sure I am not inadvertently cooking my new engine!
Thanks for your help,
Andrew Butler
RV7 EI-EEO
17 hours flying
Galway Ireland.
Andrew Butler
RV7 EI-EEO
17 hours flying
Galway Ireland.
