Hi all,
New to the forum, looking to purchase a 6/6a. need help on two i'm considering:
first one has suspect compression, what is time and $$ to overhaul if necessary? says he has "staked the valves" and going to re check them first. anyone heard of this, is it common. engine has 3350TT and has 1110SMOH. plane is in great condition otherwise. need some help/thoughts
second has fuel tanks that were sealed using "sloshing method" he's opened tanks and checked them, said "found that the only loose sealant was on the inside of the four end ribs and of course this was removed. The rest of the sealer was bonded tight I thought it best to leave it well alone. All access plates and fuel sending units were then reinstalled with pro seal and should last for a long time..." i've heard concerns over this method of sealing tanks and am looking for thoughts on this particular plane. again, otherwise plane is in great shape.
thanks in advance for the help, this is a great forum and i'm enjoying it already!
Matt
Matt
