Looking for these brackets
rv6ehguy
Patron
Hello fellow RVators,
I’m looking to purchase a few of these brackets.
Can anyone point me in the right direction?
I think the model number is UMPCO MS9365-11.
I could order directly from UMPCO but I only need
a few, not a thousand. My use is the same as pictured.
I could make them from aluminum but I prefer cadmium
plated steel. Thanks in advance.
John Van Lieshout
RV6A QB 85%
C-FMYM (reserved)
AeroSport Power IO-375M1S 195hp
Garmin G3X Touch 2 screen suite
(Still looking for a prop)
Closer picture
Here’s a closer view of what I’m looking for.
You could always use a cushioned clamp, say WDG-10 or so, pull the rubber off and twist it..
The UMPCO MS9365-11 is a flat bracket that was bent by the builder. Here is the data sheet. https://www.alldatasheet.com/datasheet-pdf/pdf/1171538/UMPCO/MS9365-11.html You could contat UMPCO and ask if anyone stocks and sells small quantities of that bracket.
Some other alternates that are not the same but could accomplish what you want:
Cad Steel https://www.aircraftspruce.com/catalog/eppages/superior08-11906.php
Alodine Aluminum https://airflowperformance.com/index.php/product/nozzle-line-bracket/
