The Wizzard
Does anybody know who sells it now/
Flyboy Accessories sell them (or something like them).Does anybody know who sells it now/
Got it, Thanks! They do have them.Flyboy Accessories sell them (or something like them).
Do you paint ‘em? How do you attach them?I 3D print my own. See, reason to buy a 3D printer!
Mine was painted separately from the rudder. I attached it using 3M VHB double sided foam tape. VHB = very high bond (strength). The foam tape is approximately 1/16” thick. Been there for 1300+ hours.Do you paint ‘em? How do you attach them?
Enquiring minds and all…
I leave it natural. Carpet tape works great for attaching it.Do you paint ‘em? How do you attach them?
Always try this first.Not to go too far off topic ... but if you have a rear light on the rudder, some use a tab under the light. Works well for my RV-8.
Great idea!!Not to go too far off topic ... but if you have a rear light on the rudder, some use a tab under the light. Works well on my RV-8.
But I can't claim credit for it. Just passing on a good idea that works well and that others are also using. It keeps the ball centered in cruise on my -8.Great idea!!
+2 for the balsa wood wedge. 20 years and still going on strong....For $2 you can tape on a small balsa wood wedge. Saves from having more holes in the rudder, adjustable (cut to correct length), and works perfectly.
I used the balsa wood wedge from the hobby store (same size as Flyboys) to test location and width to get the desired yaw effect. Then installed the Flyboys plastic in the same place with epoxy glue. Still there.For $2 you can tape on a small balsa wood wedge. Saves from having more holes in the rudder, adjustable (cut to correct length), and works perfectly.
