N546RV
Cutting to the chase, I'm finally getting my hands dirty (literally) with fiberglass work. While working on my rudder bottom, and sanding the tail light pad flat, I went too far and needed to build it back up. So I laid up a few plies, then cleaned the area up and got ready to do my first bit of micro work. I mixed to what I thought was an appropriate peanut-butter consistency, but within 15 minutes of applying it I realized I definitely left it too wet, and it wasn't staying put:
Fortunately it didn't run too much, and tonight I got that mess sanded down and looking nice. Then I got ready to build up my rudder tip a bit to match its contour to the vertical stab tip. In the intervening time, I watched the EAA composite videos, and got a useful new metric for dry micro, namely mixing it until the stuff didn't "sag" at all.
Tonight's mixture didn't run, which is good, but I found it extremely hard to work with. I never could seem to get it to lay down nicely, no matter how much careful work I did with a plastic spreader - half the time, it'd stick to the spreader and pull away from the work piece. Eventually I gave up on creating anything resembling a pleasing shape and just gooped on enough stuff that I figured I could sand this horror down to a semblance of the final shape:
What I'm wondering is whether I made this batch of micro too dry, and maybe that's why it was a real pain to spread? Or is this just me needing some better technique for spreading the stuff? Any other thoughts or advice to offer?
![img_2955-1024x768.jpg](/proxy.php?image=https%3A%2F%2Frv-wp-static.s3.amazonaws.com%2Fcontent%2Fuploads%2F2022%2F01%2Fimg_2955-1024x768.jpg&hash=aeaf88a48d08d970615e32c51d2920dc)
![img_2964-1024x768.jpg](/proxy.php?image=https%3A%2F%2Frv-wp-static.s3.amazonaws.com%2Fcontent%2Fuploads%2F2022%2F01%2Fimg_2964-1024x768.jpg&hash=4c2f8741cac6e29b6a6b2c7c3bba871b)
