1.The Preview Plans suggest a bench grinder, and it looks like "deburring" is most effective with a Scotchbrite wheel....do you suggest a variable speed or just a cheapie 6" single speed 'HF special'?
2. 1" belt sander required/suggested ???
3. Suggested size of an air compressor to use with Pneumatic Riveter....leaning toward the HF 3 HP, 10 Gallon, 115 PSI Air Compressor, capable of 5.6 CFM @ 90 PSI, or do I need more....looking to do most of the prep and assy in my basement
4. Was gonna go with the Cleveland RV-12 tool kit as suggested by a friend who is building an RV8 (significantly different construction for him, but he likes their tools, service, etc....) HF has a lot of the tools for alot less, such as the metal-cutting snips, but I suspect there's a quality difference ????
5. Suggestions on what type of hand drill work best......leaning toward a nice small lithium battery-type with > 1200 RPM, but open to suggestions from experience
6. Finally, I need to assemble a workbench.....would like to do that right the first time......appreciate any suggestions or pointers on size and construction of that....top surface, etc?
Thanks again in advance for your suggestions! BTW, I live in S.E. PA, just north of Valley Forge Park and currently fly a Cardinal based at PTW! And yes, I'm gonna track down the local EAA guys, but as far as I know, there are no RV-12 builders nearby and that's the input I most value right now in the prep stage.....den
